3_tons
Aug 19, 2018Explorer III
marcsbigfoot20b27 wrote:
OP here,
I’m happy to report that today outside was 109 degrees at 1400 ft and the 2200i had absolutely no problem firing up the AC on ECO mode, including cycling the AC. Remember however I do have the Micro Air easy start installed
Density altitude calculates at about 5180 ft.
Home power with 25ft 10 ga contractor extension cord was 112 v while runnng on high.
EU2200i (I should have run it through the same extension to be fair but didn’t think about it) was running 122v on high.
Good to know Sir, thanks for the update and performance report...As for mine with the 2200i, the jurys still out but since the ac works perfectly off the inverter, I now beginning to think that I may be getting some voltage loss across a ATS switch (theory only here) but since I’m now on the road it’ll take awhile before I can do any more checking...
3 tons
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
