ktmrfs
Sep 19, 2018Explorer III
crcr wrote:wnjj wrote:crcr wrote:
If one were buying a new eu2200i for RV use, would it be recommended to buy the Companion rather than the regular model, in order to have the 30a outlet?
No, because it’s not the same outlet as an RV needs, and the generator cannot exceed the capacity of the 20A outlet.
I understand the outlet is different, but one could buy an adapter to plug a 30a RV plug into it. Question: Is that outlet 30a when the Companion genset is run by itself? Or only when it is paralleled with another eu2200i?
30A outlet is powered at all times. No you don't get 30A with only one generator, you get 2200VA peak, 1800VA continous when running by itself.
you get 3600VA continous, 4400VA peak when paralleled with another 2200, or 3400VA continous, 4200VA when paralled with another 2000.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
