KendallP
Apr 11, 2016Explorer
PaulJ2 wrote:
Two things will make the fan clutch act abnormally. A radiator with airflow restricted a bit with bugs will come on earlier because of not enough cooler fresh air on the clutch spring.
The other fail is when the radiator tubes plug internally restricting water flow and the clutch spring does not feel enough heat to engage at all.
That's it?
So you're saying a fan clutch never will act abnormally due to its own failure?
I have always run my own screen in front of the radiator and do change it yearly. Its current status is relatively clean.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
