KendallP
Apr 15, 2016Explorer
MEXICOWANDERER wrote:
...You lived how many years without a complaint with the heavy duty OEM fan clutch? now replacing it with the same part number raises noise issues? Now stop and think: Do you Reeeeeally believe GM put a standard duty fan clutch on a P30 with 454 chassis?
Or are you going to keep trying to re-invent the wheel? :)
If you'd spend more time actually reading instead of defaulting to your favorite passtime of breaking your adopted grandson's huevos, you would know that the write up was NOT talking about the OEM, but rather a lighter duty Delco clutch that runs high when disengaged. THAT is why the guy likes that unit for the hot desert and THAT is why the unit is noisy... ALL THE TIME. Not just when engaged... LIKE MY BELOVED OEM!!!
I absolutely DO want exactly what GM put in there 30 years ago. Problem is... today ain't 30 years ago.
Found one at O'Reilly's. A Murray made by Hayden. It's exactly the same, visually as the Chinese Delco. I'll let you know what the scale says.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
