RVentura's avatar
RVentura
SOLVED AC not charging storage battery Fleetwood Jamboree Rallye 01
Hello, I am new to the world of RV-living and have encountered a problem I am hoping you will be able to help me with.
Basically I am parked with the AC line plugged in and everything seems to work fine but after a few hours I get a beeping noise which seems to be an indicator of a low battery. I run the engine and then the generator for 15mins each and it's good to go for another 5-6 hours.
I don't use much electricity and the only thing constantly drawing power is the refrigerator. I was under the impression that while hooked up to AC everything should be able to run off that and the storage batteries should be charged by it.
I actually changed the storage batteries twice already due to another beep which was the gas detector I believe so the batteries are brand new (this is what the RV mechanics said would solve my current issues but sadly it did not). I can't afford to take it back to them for now so I am turning to you. I hope you can help me solve this problem and I thank you all in advance.
Rventura
