Tom_Barb
Jul 11, 2015Explorer II
RJsfishin wrote:Tom/Barb wrote:RJsfishin wrote:
You said that running the generator charges it ? If the genset charges it, then the ac electric shore power should be charging it also.
If not, then the automatic transfer switch (ATS) that is suppose to switch the ac source from generator, to shore power has failed in the generator position
One must remember the Generator has priority in the transfer switch. I'll qualify by saying at least mine does.
Yes, so, does that change any thing I said ?:h
With the gem-set running, it will be charging the battery and supplying the house power, the AC chord does nothing.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
