SlowBro's avatar
SlowBro
Explorer III
Jul 16, 2021
[SOLVED] Buy if slide out is sluggish?
I'm looking at maybe buying my first RV with a slide to full-time on the road, but the owner demonstrated that it's sluggish when sliding out, he had to give it several shoves at the top to get it to move. He thought maybe it just needed a lube. This is a super slide which contains the couch and kitchen.
Would this be a very bad sign and I should avoid, or is he probably right that it only needs a lube? We would be sliding it in and out quite often since we would be on the road.
  • Slides shouldn't need lube, that attracts dirt. I would check for misalignment.
  • way2roll wrote:
    As mentioned, could be lots of things. Low battery, misaligned, not lubed, or something very serious. I have to think that's one of the things that would scare me away from an RV. A non working slide is a big deal if it needs fixed and possible could leave you stranded. I would have to ask, if it just needed lube why didn't the seller take care of that already?
    That's a good question. It is otherwise well-maintained, and he was living in it, parked all the time, not really traveling, so he might not have thought it important. I'll ask him to lube it if we get serious, and if he's not willing we'll pass, and if he lubes it and it doesn't improve, we'll pass.
  • As mentioned, could be lots of things. Low battery, misaligned, not lubed, or something very serious. I have to think that's one of the things that would scare me away from an RV. A non working slide is a big deal if it needs fixed and possible could leave you stranded. I would have to ask, if it just needed lube why didn't the seller take care of that already?
  • It could be a number of things causing improper operation of slide, but having a mobile tech check it out, before purchase, would be best. Then you will have a better idea, of the seriousness of the problem. Many slides do not require any lube, or special attention, but being in proper adjustment is critical, for regular use.
    Jerry
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
