time2roll
Jan 03, 2021Nomad
A 45 amp converter is fully capable of putting 45 amps into the G24 battery. Although depending
on the converter brand and charging profile and the 12v wiring you may not get 45 amps for long or only half that amount. A good converter could put a solid 45 amps in for maybe 30 minutes before the battery acceptance rate causes the amps to begin tapering off.
If you were buying a separate charger a 10 amp rated unit would work perfectly good.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
