valhalla360
Jan 04, 2021Navigator
SlowBro wrote:
those cheap and inefficient Chinese generators and my van uses less gas per hour idling, despite having a larger engine.Gdetrailer wrote:
Most car alternators are designed for INTERMITTENT heavy charging
Oh then that's perfect. I have in mind intermittent use, otherwise I would be buying solar.
By INTERMITTENT heavy charging, that means for a few minutes at a time. Basically when you start the motor, it's pulling hundreds of amps to turn the starter for a few seconds...so a few minutes charging at 80-100amps will replace the amp-hr that were pulled. After that it just puts out a few amps to run the lights, radio and other light loads. Nothing close to 150amps.
You can buy specialty after market alternators designed to put out high amperage for a longer period of time. Most are geared toward full size pickups with big V8 engines that won't notice the power needed to run them. They are also frequently optimized to put out significant amperage at lower engine RPM.
As you indicated it's the stock alternator, I would be very surprised if it can withstand anything close to 150amps output for more than a few minutes. If you are lucky, there will be a cut out that stops the output. Otherwise, very good chance of burning out the alternator. (This is made even worse by the idea of doing it with the vehicle parked and no airflow flushing the heat out of the engine bay)
From the battery to the inverter, you will need some pretty heavy cables as you are going to be pulling upwards of 80-100amps off the truck battery.
You will need to look at the continuous output of the inverter. Usually, they give a peak load rating as the main number. That peak load is usually only good for seconds or minutes. There is a continuous rating (often hard to find) that is much lower.
If you upgrade everything from the alternator thru the inverter to handle the loads, it's pretty straight forward and at 120v, the cabling to go back to the trailer converter (charger) doesn't have to be excessively large due to the higher voltage (typical extension cords is good for this size load) and as previously mentioned once you get 120v power of sufficient amperage back to the trailer, the converter won't know the difference between your system and shore power.
If you have the alternator that can provide the amps, it's actually a good solution to charging while towing (not so much while stationary). The problem with charging directly off the 12v system is the wires going to the hitch are tiny and often the connections are of poor quality with low voltage (12v) you get a lot of power lost. This results in only a few amps making it back to the trailer battery.
Probably not worth replacing the generator if it's in good running condition but watch and you can find a good quality inverter generator for $4-500 (helped a friend pick out a 3100w dual fuel Champion last summer for $500). And yes, they do save on fuel consumption compared to the old cheap fixed speed generators. Only under high loads will it be comparable fuel consumption. So an 800w load on a 3000w generator will be throttled way back with an inverter generator and do significantly better (and be much quieter).
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
