AnEv942
Sep 25, 2013Nomad
DING DING DING!
Wow-where did you find that?Ohhhh
Exactly what I have. I'll be dipped...copied to my cpu.
THANKS! Chris.
Cool, since the factory fan isn't used Ill disconnect completely for the moment-rewire later like it should be as a back up, obviously mine has been hacked.
The thermo disk is 158°-hottest I've measured on a 102 degree day where disk is located is 140° so fan never has come on -and as its currently mis-wired even if disk was lower fan wouldn't come on unless refer was running on 12v heater. Wow-been like this I assume since recall work done several years ago..
At any rate The loose blue wire I was stressing over, as wire coming down behind coils from fan is red must have been spliced behind coils to blue somewhere and I pulled it loose when removing the heater wire. non issue-awesome
Mystery SOLVED! Thanks again Chris
THANKS! Chris.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
