rejesterd
May 20, 2020Explorer
Well, wnjj's suspicion was correct. After I shoved the probe in a little further, I get 12V at the both sides of this connector. I also get 12V where the blue wire connects to the thermostat's red wire (in the same pic above) with that crimp cap. It feels like a pretty solid connection, but still no voltage at the thermostat end.
So I think that means I need to run a new wire. Anything else I should check before concluding that this is a short somewhere behind the wall? That makes the most sense, since the fuse on the thermostat blew a couple years back.
On the plus side, at least I've found where the mice are getting in..
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
