wnjj
May 20, 2020Explorer II
Your best bet may be to head down, through the floor and back up into the furnace. Consider cutting a hole in the wall just above the floor and then cover it with a mud ring and blank cover plate. By putting this near the floor, you can angle a drill down through or drill up from the bottom and use hole to allow you to feed the wire. This assumes you can drop a loose wire down all the way from the t-stat hole without framing in the way.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
