rejesterd's avatar
rejesterd
SOLVED: No power getting to the thermostat
SOLVED: It was a short somewhere between the blue wires at the furnace and the tstat. Refer to this post
Hi All,
1997 Terry 30g RV with an Atwood 8531-III DCLP furnace and a Coleman 7300 air conditioner.
I just opened up my camper for this season, and found that power is not getting to the thermostat. The heat, AC nor the fan work. The last time this occurred, it was due to the small 2A fuse on the thermostat itself. However, i removed it today and it has continuity and the connection points look clean. This is an older Coleman thermostat..
I can confirm that I get 13.something volts at the circuit breaker on the furnace.
I checked the voltage at all 3 connection points to that breaker (the 2 red wires and the blue wire).
What would be the next step to troubleshoot this further?
Thanks as always.
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 08, 2026
