wa8yxm
Aug 18, 2018Explorer III
Ok most LED lights. you reverse the polarity and they simply do not work, Fix it and they are good again. The LED is kind of an electrical check valve. You put a check valve in a water line backwards. it don't work (Water will not flow) same with the LED's
HOWEVER if they LED's have an electronic controller.... (Dimmer. color selector. effects generator) then ... You may have fried the controller. It is not always protected...Less I install it.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
