wa8yxm
Jul 01, 2013Explorer III
What you need to run the Microwave is AMP HOURS.. AGM's have no advantage (or disadvantage with one exception) over other types of batteries when it comes to amp hours (the exception is Optima which has 60% of the capacity of other types of the same form factor).
Though I will admit AGM MIGHT (emphasis there) be a bit easier to recharge and seem to hold the charge better (less internal self discharge) still what you need is AMP HOURS.
And the amp hours per pound is the same for all battery types (Even optima which are 60% as heavy as other batteries of the same form factor).
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
