full_mosey
Jul 02, 2013Explorer
HiTech;
Last year, I used my 79AH Deka to boil a qt of water with an inverter and a 900+W elec kettle in 7 minutes. The kettle whistled at 11.6V. Over a few minutes, there was a rebound to 12.37V.
That equates to a C1 draw of 900W/11.6V = 78A from a 3+yo 53lb 79AH when new battery. That is encroaching into CCA territory. AGMs are all hybrids. This means flexibility in switching between low and high draws.
With GCs, you cannot handle high draws like C1 and keep your inverter running. Is there a BCI rating system that give any guidance on this? All of the BCI tests I have seen use low volt thresholds way below any inverter LVD ratings. I want to know what is going to happen if I draw constant Watts, not constant Amps.
With GCs, high draws are handled by adding batteries to divide the draws between multiple batteries so that the draw per battery is reduced to a low draw. For example, the 78A draw in my test might be spread across 4 x GCs at 20A per battery. IOW, with GCs you transform a high draw into a low draw by adding batteries until you arrive at a low draw.
HTH;
John
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
