full_mosey
Jul 02, 2013Explorer
HiTech wrote:
You can get the info from the discharge curves for the battery. My East Penn Batteries match the factory curves well (even outperfom them a bit). No idea if there is a BCI standard for this. Seems like many tests end at 10.5v
Jim
The CCA test ends at 7.2V. That is useless in evaluating how long a constant Wattage inverter might run until LVD. The RC tests use 10.5V, but then again, that is a constant current not a constant Watts test. Same problem, but at least the Volts are closer to LVD.
We need to run our own tests.
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
