pnichols
Jul 06, 2013Explorer II
Mena,
As you know the Ford E450 chassis under many Class C rigs is a ton-and-a-half chassis ... more beef than a one-ton pickup.
My small Class C's E450 has a 5000 lb. tow capacity and the motorhome underloads the chassis by about 2200 lbs. (the DW likes to collect a lot of rocks on trips!). My E450 chassis can travel with a combined motorhome-trailer weight of 20,000 lbs.. I believe the new E450's under motorhomes are rated a bit higher and can handle 22,000 lbs. in combination between the motorhome itself and anything you might want to tow.
As a point of reference, my daughter hauls one and two horses around all the time with my GMC 1/2 ton 4X4 350ci gas pickup. However, I did install an after-market front differential manual engage/disengage mechanism so she can be in 4X4 low range but still in two-wheel drive. This allows her to get terrific torque in two-wheel drive for pulling the horse trailer up steep grades on hard surface grades (4X4 drive on hard surfaces will wrap-up and ruin my truck's non-front/rear-differentiated drive system).
1-ton trucks with diesel engines are not always needed for less than over-the-top hauling ... with one important exception: IMHO, in case of a rear tire blowout for the safety of the horse(s) one should always, if one can afford it, haul horses with a dually tow vehicle so you have another tire left on each side if a rear tire should fail. We so far cannot afford a dually pickup for her horses, so we're taking a chance with the horse(s). :(
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
