brulaz's avatar
brulaz
Sp.Gr. of Golf Cart 6v batteries
Trailer came with 2 6v US2000 golf carts last fall. No idea what their actual age is.
Tried to take care of them with full re-charge the day after ~50% depletion (~12V) with Prog. Dyn. 6280, and later with built in tiny solar during storage.
Added larger solar and Rogue MPPT a month ago. Started doing Rogue's equalize at 15.3V for 2 hrs every few weeks then.
Finally got a half-way decent Sp. Gr. meter (glass tube with bobber) today and measured Sp. Gr of the battery cells: all three cells of Battery #1 (+12V terminal) are ~1.285, all 3 cells of battery # 2 (-12V terminal) are ~1.275. Temperature is 19C. Roque is in float mode at 13.1V.
No idea how accurate this Sp.Gr. meter is (auto store special), but at least it's consistent. All cells of the same battery give the same reading.
So what does it mean? I think both batts are fully charged. But should I be concerned that one has a slightly lower sp.gr.?
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
