azrving
Sep 02, 2013Explorer
So you said fuel as in gasoline right? You are doing right by running that often. It keeps the carb from drying and gumming the fuel in the bowl. Also keeps seal lips and engine parts lubed. The fuel in the tank is still getting old but when you run it that is the most you can do to prevent carb trouble.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
