benevolus2's avatar
benevolus2
Spark plug gap question
I purchased the HF Predator 3500 generator yesterday. The manager is contacting the maker for me to clarify the oil change intervals. I will update.
The manual recommends the plug gap to be .027"-.031". That's kind of a range here. Anybody comment on the best gap? The average would be .029". Which gap would you feel would be better at 2500 feet? Tech support is of no use.
Thanks.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    DownTheAvenue wrote:
    I think you are way over thinking this issue. Just set the gap in the middle of the range and call it good. That engine will not care, believe me!
    Ditto.. One well two suggestions
    One when you buy New Plugs. P-Tips (Platinum) 100,000 Mile rated plugs
    Two. Take them out of the box.. Hold all of them Threads UP with the "Ground" contact off to the same size and look at 'em.. IF you find one where the gap is way smaller than the rest.. That plug was dropped and damaged.
  • rjxj wrote:
    Dont worry about the gap and the spark plug will last just about forever. The initial oil changes are very important imo. Get a few hours on it and change the oil. They probably recommend 20 to 25 hours at least for the first change. Small engines often recommended 25 hours depending on the application. My Honda is every 100 hr but I changed it at about 2 then 8 or so then 40 and then keep it under 100. You will probably see a swirled almost metallic look to the oil at first. This is important.
    If you are running it under heavy load high heat conditions all the time then tend to change the oil sooner. Oil is cheap.
    Edit: I went out and checked my oil change record:
    2, 6, 72, 146, 325, 446, 526, 604
    Thank you. I also change my oil frequently also. I run my Honda 2000's 8-12 hours at a time at my camper. Always changed it every 40/60 hours. What's 13 ounces?
    Have over 3500 hours on each. Thanks again
  • ScottG wrote:
    Also, if you use a platinum plug you really shouldn't gap it.
    That also applies to Iridium ones too.
    Another vote here for not being OCD and over-thinking it.
  • Dont worry about the gap and the spark plug will last just about forever. The initial oil changes are very important imo. Get a few hours on it and change the oil. They probably recommend 20 to 25 hours at least for the first change. Small engines often recommended 25 hours depending on the application. My Honda is every 100 hr but I changed it at about 2 then 8 or so then 40 and then keep it under 100. You will probably see a swirled almost metallic look to the oil at first. This is important.
    X2.
    I have played around with gaps on engines and it makes no difference as long as it's in range.
  • I would set it to lower tolerance.
    Electrodes will burn out over the time and make the gap bigger.
  • It's not rocket science, years ago we used a match book cover or just eyeball it.
  • I think you are way over thinking this issue. Just set the gap in the middle of the range and call it good. That engine will not care, believe me!
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
