fj12ryder
May 21, 2018Explorer III
Lynnmor wrote:They recommend against it because of user error. Not any inherent problem with anti-seize. And it probably isn't as necessary as when heads were made of cast iron. I always use a dab and I've never had an issue with plugs coming loose, or worse, not being able to remove them. But it's just like Brylcreem.
Be careful using anti-seize on spark plugs, especially in aluminum heads. Many engine and spark plug manufacturers do not recommend it. Here is just one video explaining the problem.
video
