I will say again. If you hook several different chargers to a battery system, be it 12 volt 24 volt or xx Volt. so long as all the charging systems are set to the same voltage.. IT IS NOT A PROBLEM. No switching needed, (NOTE This applies ONLY to DC systems) as the one with the highest output voltage wins and gets the job of charging while the others automatically idle or at the very least throttle back big time.
IF you are worried that multiple chargers might exceed the battery charge rate then (for a 24 volt system)
Run multiple charge controllers.. Stage one (All sources) set to like 30-40 volts, these the outputs go to the input of the 2nd stage. Set up for the battreies.. Or alternatevely you can get one that limits current only but .. While I know how to build one, I don't know where to buy one.
