KenFecher
Apr 12, 2016Explorer
ddndoug wrote:
KenFecher - Do you have the name and model number of the speakers involved? Based on that information, we may be able to suggest some speakers to help balance you out. Personally I'm a huge fan of JBL marine speakers and Polk Audio marine rated. Both are very efficient with sensitivity levels of 91 db and 92 db respectively.
Doug
I have not been able to climb up and look at the speakers, or pull them to see make, model, watts, ohms etc. At first thought it was a wiring issue. That has been checked, and fixed for that matter. Fleetwood had it wired so that each inside speaker was wired individually to Speaker A on/off and Speaker B on/off, but each to the left side output of a connection set for left and right output. I suddenly have stereo inside with much richer sound. :)
I said in another response, I actually like that the speakers are cheapies. I'm not looking for power and hi-fidelity, I'm looking for balance so that one master volume control doesn't control inside and out because of the insane imbalance.
Thanks for the information. I like getting all the input I can.
