KenFecher's avatar
KenFecher
Speakers produce uneven sound.
We have a 2014 Fleetwood Shamrock 233 S. LOVE this camper, but curiously the stereo system has switches to turn speakers on and off. One does one inside, another does the other inside and the last turns on the outside.
If you would like inside and outside on at the same time, you have to blast the inside speakers to get anything usable to come out of the outside speakers. Is this proper?
The stereo is a Genesis system.
  • KISS! Start from the beginning. Burnish ALL of the connections and I'll bet you dollars to doughnuts your problem goes away. And please avoid sharing your impeccable entertainment choices with others.
  • Common and expensive to fix. You need a low signal input to an auxilliary amplifier which would have it's own volumne control knob for the outside speakers. Make sure the speaker impedence is correct for the amp.
Having RV issues? Connect with others who have been in your shoes.24,339 PostsLatest Activity: Nov 28, 2025
