pnichols
Nov 03, 2018Explorer II
MEXICOWANDERER wrote:
That is a home unit and it must be allowed to cool.
I have tested three or four group 31's then let it rest.
- Find out or best guess a battery's CCA. Golf car batteries use different numbers and time
- Regular batteries use 50% of CCA rating
- 500 CCA battery test at 250 amps. Charge battery and twist dial to get 250 amps
- Watch voltmeter
- Maintain 250 amp load by twisting dial for more load
- Keep it at 250 amps for FIFTEEN SECONDS
- If the voltage sags to below NINE POINT SIX VOLTS the battery is defective
- Most bad batteries voltages collapse under a very modest load.
Thanks for the details on that unit.
Those load application times are so short that probably there's not a lot of heat to deal with if the user lets it cool long enough between those short load application times.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
