MEXICOWANDERER
Nov 22, 2018Explorer
CA Traveler
That would be better than nothing. Pay attention to the volt scale when load is turned off. If the return to 12 volts is a -lot- more sluggish after the 2nd load test then that is not a good sign.
Have the batteries connected in series and after the test if the series cable is hot, the test is void. The cable must not heat up.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
