naturist
May 17, 2014Nomad II
Motor oil and diesel fuel are mutually soluble, so very unlikely to form separate layers. Between suck-&-mix of oil pump and oil spray coming off the bearings and bottom edges of cylinder walls, you got some strong mixing going on. If you are getting diesel in the crankcase, you gotta change the oil before low lubricity ruins expensive pieces.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
