markchengr
May 17, 2014Explorer II
Diesel fuel is quite soluble in lube oil. If your crankcase level is increasing with no indication of water present then what you have is known as fuel dilution. It is quite common in the large marine diesels I have worked with. You need to not only change your oil but find out where the fuel is leaking into the engine. Many diesels have been ruined by fuel dilution. Usually the only indication is rising crankcase level and possibly but not necessarily a decrease in oil pressure. I'm sorry. I know this is bad and probably expensive news. Good luck. -Mark.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
