BFL13
Oct 12, 2012Explorer II
Too early to panic. the low SG would be from stratification more than any actual sulfation, where they didn't get deep cycled much to keep them stirred.
I get the same thing when on solar---the batts don't get low enough to do a proper deep cycle and SG gradually sinks even though the solar is doing ok by its thinking.
I still need to do an over-charge on the batts once a month even when on solar or SG never gets up to tippy top as new.
The over-charge and its bubbling should get it done, but I like to a real deep discharge to 50% also. I am unclear how that compares with just getting an over-charge going for actual amount of stirring.
Sounds like you need a calendar with a place by each date to write down things and then fill in your battery schedule ahead of time. then all you need to do is remember to use the calendar :)
