landyacht318
Oct 27, 2012Explorer
If the controller is the solar bottleneck wouldn't it get hotter than normal? Which is not the case, it is barely warm.
The test you outline would be an absolute curse fest due to tight spaces, and thick inflexible wires shoehorned into undersized receptacles.
Guess I could run temporary wires from panels to battery to bypass the curse fest.
I think the unisolar 68 watt thin film has a few dead cells. OPen circuit voltage should be a good and easy test for that.
