realter's avatar
realter
Spending too much $$ on batteries.
The TC I purchased new in July 2009 had a Lifeline GPL27T battery. Lasted until Oct. 2011, when Rex told me I needed a new one. I was at factory getting a window put in my door. Last fall, October 2012, this battery would not hold a charge, so this spring I am forced to start looking at batteries again. Have put off using the camper until now because I can't afford to keep buying $300 batteries. Any suggestions??
  • You might want to check your charger system or your battery charging/maintenance routine. I have two of the same batteries in my TC purchased in late 2007. Both batteries still going strong.
    Jim
  • IMHO opinion the best bang for the buck is normal flooded wet cell batteries especially if you can't or don't know how to care for the speciality batteries (they require special charging conditions dependant on the battery type). Any battery must be properly cared for, for example do not leave a battery connected to your TC allowing it to completely discharge due to parasitic loads. A few completely dead cycles and left that way will kill any battery quickly
    Unfortunitely getting 2 to 3 years out of battery is about normal if you don't pay attention to battery maintence. Get as big a marine duty 12 volt FLA battery as will fit in your TC (cost about $100), make sure you charge it before storage and disconnect it during storage would be my general recommendation
  • $300 for a single Group 27? Way too much, check Costco, Walmart, SamsClub, etc.
    I would suspect your battery charging is the issue. Bad charger? Leaving it uncharged but connected for weeks/months?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
