Moffittclan
Mar 15, 2016Explorer
Splendide 2100xc vented washer dryer
We just installed a used unit in our MH. Never had one before. I started the dryer and let it run to verify it was venting to the outside well. It did vent outside but it was also blowing hot air out of the area where you put the soap. Is this normal? It may be but I can see that it would add some heat to you home if it's running a while...
