We have the Splendide 2000 and lately it has been taking forever to dry small loads. I checked the manual and cleaned the pump pre-chamber, but it didn't seem to help. Any ideas?
If you can access the back of you unit, check the exhaust hose. On most install they uncrate the unit. Hook one end to the back and the other to the vent without any concern of proper length. Mine had exactly the same symptoms. Pull the hose and there was a grapefruit size wad of wet lint. Then take a flash light and shine it in the back of the unit as someone looks and rotates the drum to make certain light is visible each time the hole pass the exhaust.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
