DrewE
Feb 09, 2017Explorer III
While it could be a need for larger wires, it would not hurt to check that the connections are good and tight first. In particular, if it's plugged in via a lighter plug, make sure that it's making good contact there all around.
The squeal is a low voltage alarm on the inverter. Since your battery voltage is fine, there must be a voltage drop somewhere between the battery and the inverter.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 16, 2026
