klutchdust
Feb 11, 2017Explorer II
MrWizard wrote:ewarnerusa wrote:
When operating off the generator you are not operating off the inverter, so it makes sense that the inverter shuts down or drops to idle while gen is running. Can you describe the squeaking? Like I mentioned, my squeak was from the inverter cooling fan.
I don't think his Elite 400w, has an in line internal transfer switch
So with generator running the converter increased the battery voltage
His inverter was giving the low battery warning
Exactly, last night I turned on the Tv and the squealing started, too tired to check the battery voltage. Ill do it once I get home after this race. i wasn't using the TV with the gen on.
As far as the LP tank ,it is a permanent mount on a class C. My TT had two tanks like you mentioned and a screw on gauge was accurate.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
