- red31Explorer
evergladesgator wrote:
Just thought i'd add this.
MB Sturgis Inc. has been the leading manufacturer of LP and Natural Gas Outdoor Appliance Connectors and Quick Disconnects for over 30 yea
And I doubt they dabble in hydraulic hoses.
They do answer their phone and have the UL/ANSI approved connectors in house! Local hydraulic hose makers don't. - MEXICOWANDERERExplorer
Hey Mex, don't quit your day job. Comedy is not your forte. Wonder where anyone said ANYTHING bout UNAPPROVED hoses ????
thanks Seems to me they were recommended by someone that makes their living at the rv repair trade.
I read the entire thread before I shovel on the sarcasm....
"Some would have you believe the hype, that there is something special about hose that carries propane. Years ago I ran propane thru a garden hose for 2 + yrs, no ill effects to the hose whatsoever. Since that time, I have used nothing but automotive fuel injection hose to plumb everything on the low pressure side in my RVs,.....cat heaters etc. 14 yrs later moved it all to next RV, and that hose is just as soft and pliable as new.
Truth known, "propane hose" is nothing but cheap junk !
Even the cheap clear vinyl hose from any hardware store is better for LP propane than the cheap hi $ propane junk. And don't ask me how I know that to be fact !" - evergladesgatorExplorerJust thought i'd add this.
MB Sturgis Inc. has been the leading manufacturer of LP and Natural Gas Outdoor Appliance Connectors and Quick Disconnects for over 30 yea - HuntindogExplorer
edbehnke wrote:
Dunno. I do use my TT a LOT, and go thru a lot of propane. And the high tempertures in Phoenix AZ during the summer is probably a factor as well.
never had to replace any propane hoses, can't think of why anyone would be considering changing these hoses.
can't wonder why someone like huntindog would have to change his hoses frequently???? interesting.
All I am certain of is that the only TT that never had propane line problems was my first one that had metal lines. - HuntindogExplorer
wolfe10 wrote:
Chris is correct. Propane hose is rated to handle full tank pressure, in the event of a complete failure of the propane regulator.
Yes, if no failure, you are talking about under one PSI. But, that is NOT what safety dictates.
The hose has to withstand full tank pressure, as it is not regulated down from the tank to the regulator. - evergladesgatorExplorerHey Mex, don't quit your day job. Comedy is not your forte. Wonder where anyone said ANYTHING bout UNAPPROVED hoses ????
thanks Seems to me they were recommended by someone that makes their living at the rv repair trade. - MEXICOWANDERERExplorerInsurance adjuster to customer
"Regarding your fire claim - we found evidence your vehicle had improper LPG hoses not certified for LPG. Here's my card. On the rear you'll find the definition for the three letter abbreviation: S.O.L." - edbehnkeExplorer IInever had to replace any propane hoses, can't think of why anyone would be considering changing these hoses.
can't wonder why someone like huntindog would have to change his hoses frequently???? interesting. - evergladesgatorExplorerThis is the one I was interested in buying.
http://www.ebay.com/itm/MB-Sturgis-Inc-100699-24-RV-Stainless-Steel-Type-1-to-1-4-IF-24-Propane-Hose/131288843883?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D28791%26meid%3Dfb75c8024e024b75bc30ecf62db68f12%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D131288843738&rt=nc
The hose itself is not much more expensive than a regular propane rubber hose. I'm tired of the rubber turning into a metal like substance. Think I will go ahead and get two of these. I would take Chris Bryant's opinion over others. IMHO, there is NO way a plain plastic hose will tolerate any amount of pressure. To prove my point, take a look at your water pump hose on your rig. Don't look like plain ole plastic to me. It's webbed to withstand a lousy 40 psi or better. Plus can y'all imagine what water taste like coming out of a 10 year old black rubber fuel hose ?????? Looks like new SS hoses for me. - wolfe10ExplorerChris is correct. Propane hose is rated to handle full tank pressure, in the event of a complete failure of the propane regulator.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 09, 2026
