MEXICOWANDERER
Jul 17, 2015Explorer
OBVIOUSLY
You do not follow' my posts and remember what I say. THE WHIFFCO MAKES A GREAT FIXED VOLTAGE POWER SUPPLY.
A Megawatt makes a SUPER stand alone battery charger. Let me clarify this for you...
A stand alone battery charger today is like a stand-alone battery charger of 70 years ago. it is manually controlled.
A Megawatt 36-amp unit will charge batteries faster than a 55 amp smart charger when set to 14.8 volts and coupled to a generator. I would call an hour of excess generator run time excessive to a fault.
You need to, yourself, with your very fingers, experiment with converter and Megawatt charge times. Using other people's opinions or deducing misapplication of converter or charger to intended use or results is er, not especially intelligent.
I never said the Wifco makes an ideal charger. I never said the Wifco makes an ideal converter. What I do and did say the Mega will do things Fartchargers can only dream of doing.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
