pointbrze
Oct 03, 2016Explorer
mjmoch wrote:
Does the battery have to be hooked up for the slide to work?
I had the camper hooked up to house plug but the slide would not work.
Fuse is good.
I previously owned a 2004 StarCraft 21SSO HTT. And yes, the battery does have to be hooked up and charged. However, you should have a hand crank tool that will allow you to open the slide without power. The tool is inserted right below the dinette on the inside of the HTT.
Good Luck! :)
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
