sayoung
Jan 01, 2019Explorer
Slownsy wrote:
How do on test if a start capasiter is working thanks.
Frank.
If you're going to go to all the trouble to pull the covers after getting on the roof just change it after you open it up.. you probably mean the " run " capacitor as very few rv units have a start cap/potential relay from the mfg. best way for either is an actual capacitance meter but if you have an older analog volt meter put a lead on each terminal & meter will swing if close to good. Visual check on lots of them is all that's needed, bulging top, leaking, bad terminal etc.
Why do you suspect cap ?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
