CA_Traveler
Jun 27, 2019Explorer III
Removing/inserting the bulbs may have dislodged the short in the socket or wiring. Remove each light socket and check the socket and wiring for chaffing, corrosion or any other issues. At the same time wiggle/pull/push the wires/connectors while watching the above mentioned fuse replaced light - if it lights well you know what to do.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
