myredracer
May 11, 2018Explorer II
If you have low voltage where you are (like below 110), I'd use propane because the output of the electric element can drop significantly. CGs are mostly where you can find low voltage and if at home, your voltage should be close to or at 120 and electric should be fine and won't notice a difference. Saving propane is never a bad idea!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
