dougrainer
May 11, 2018Nomad
myredracer wrote:
If you have low voltage where you are (like below 110), I'd use propane because the output of the electric element can drop significantly. CGs are mostly where you can find low voltage and if at home, your voltage should be close to or at 120 and electric should be fine and won't notice a difference. Saving propane is never a bad idea!
I should have mentioned this. ALWAYS monitor your 120 line voltage with a Multimeter. ANY 120 voltage below 110 will yield inadequate cooling on 120. So, switch to LP when line voltages are too low due to demand in the CG. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
