dougrainer
Jul 06, 2018Nomad
With the engine running, have someone open and close the entry door to engage the step switch. With a hammer, whack on the silver part of the motor when the step light starts to come on when the door is opened. Do this, until the motor engages and extends. THEN REPLACE THE MOTOR. No Motor handy? Remove the motor and tie up the steps in the retracted position until you get a replacement motor. If you do NOT, the steps will fail again and you will have to do this all over again. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
