3_tons's avatar
3_tons
Explorer III
Aug 06, 2021
Stick-house Smoke detector question
Well last night there was a change in the wind and now another season of Calif exporting it’s wildfire smoke (et al…) into Nevada - Ugg…
Our house is only a few years old, so is uber tight and insulated (as tested per code.)…Yesterday, the sky was fairly clear, but apparently after dusk the wind direction had changed…Last night 3 or 4 of the Kidde (home depot style) hard-wired smoke alarms went off last night (0030hrs), two of which were in rooms with their doors closed, and one within an expansive hallway…I then awoke suddenly and combed the entire house and yard and even the attic but saw no issues and had yet to smell any smoke…Though it seems the nearest fire is of a considerable distance away, this morning I noticed some fine ash on the patio, and the air is BAD here today…
But in the aftermath, what’s most curious to me is that all of these smoke detectors sounded at the exact same time, and I don’t know by what mechanism they could do this in unison??…Any ideas would be greatly appreciated, Thanks,
P.S. Sure is some tough news for those affected :(
3 tons
  • Hardwired smoke alarms are often connected. So if one goes off they all do. I know there are laws here in California requiring them to be connected, it's possible Nevada does also.
    I had that problem in that when I opened the bathroom door after a shower, it would set off the hallway alarm, which set off the two bedroom alarms even with the doors closed. As they were all within 2 feet of each other, the noise was extremely obnoxious.
  • If your home has been built in the last 10 years in the U.S., chances are they are wired together to intercommunicate. This sort of wiring guarantees that if one alarm in the house goes off, they all go off.
    California requires it NV may also.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
