Kountryguy's avatar
Kountryguy
Sticky Dump Valve
I put a safety dump valve on my discharge pipe. It is difficult to open and close. I took it apart, cleaned it and reassembled it with no improvement. Any suggestions? Could I put some petroleum jelly on the seals without damaging them? Thanks for any help.
  • You might have tighten the two halves too tight against the seals. Try loosing the 4 bolts a little and see if that helps.
    I'd try a little silicone grease.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
