big_whitey's avatar
big_whitey
Stinky gray water
How is it possible that the gray water smells so bad when i always dump immediately after showering? We boondock exclusively and schedule our showers to coincide with areas where we can dump afterward so it never remains in the holding tank over 15 minutes before dumping. And no it is not because we are too nasty,Lol.
The only other water that goes and stays in the gray tank for any length of time (2/3 days) is just from brushing teeth as we wash all dishes outside. And no our breath is not that bad,Lol.
  • Why are you sniffing the grey water ?
    Like many, my grey smells worse than the black.
    RV tanks are "holding tanks" not a septic system. They are a closed vessel (vented on the roof), designed to keep you and their contents separated. Who cares what the contents smell like. The only time you should be near the contents is during dumping.
    Don't worry about it,
    Doug
  • Why do you shower?
    No really why?
    Because you are dirty, have body odor, hair is sweaty, bacteria, etc.
    What do you use to clean off with.......shampoo, soap, toothpaste
    Guess what.....that stuff stinks.
    Bottom of waste tanks always have some water and stuff left behind.
    Drain line comes out the side of tank so there is a lip.
    "Stuff" builds up
  • We use one cup of Borax powder dissolved in 2 cups hot water and one cup of Dawn Platinum dish detergent after every dump and we don't have any odor issues anymore in the gray tank.
  • joebedford wrote:
    Our grey dumps always smell worse than the black dumps.
    X2
    So where does your outside dishwater go? On the ground, or in the gray tank? I HOPE in the gray tank!
    Regardless of how soon you dump, there is always some remaining water left in the tank, and the tank is a moist wet environment with soap, hair, body dirt, etc. Of course it's going to grow stinky stuff!
  • Mine don't ! But then I'm not one of the cheapskates that's too cheap to use a little blue in the grey too.
  • Gray water stinks.
    Consider trying the Geo Method to keep your tanks a little cleaner.
    But, they still stink.
    Did you check the air admittance valves under the sink(s)?
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
