BigSpenda864
May 22, 2018Explorer
Fire Instructor wrote:
On a previous unit, I had basement doors that had no locks. The foam material was inadequate to secure locks to, so I removed the doors, carefully scraped most of the foam material from the back side of the door, and cut and glued a piece of plywood in place of the foam. I made sure that the hinge screws went into the plywood by using a much longer screw, so that the door was properly supported. Can’t remember if it was 5/8” or 3/4” ply.... I had that unit for another 7or 8 years, and it was still fine when I traded it. A benefit was that I was able to screw storage clips to the back side of the doors to store small items like the stabilizer crank and the 30 to 15 amp adapter....
I found a website for Trekwood RV in Indiana. I called and talked to the lady in the parts department and they indicated they could take my VIN and measurements and have the door specifically for my unit color matched. I will likely go this route. It looks like its $150-$250 depending on the size of the door.
