camp-n-family
May 22, 2018Explorer
Subscribed. I'm having the same issues with both storage doors and my outside kitchen door. The inside material is all bubbled and delaminated and the doors are soft inside.
From the factory, the metal trim around the doors never had caulking around it. I was told they had a tape sealant inside and didn't need anything else. Once I noticed the water penetration I caulked the outside around all the edges. It didn't seem to help as the doors got worse. I can't see where the water is getting in them.
Instead of replacing the doors I'm considering trying to repair them. New doors won't match and I have several decals that cross them that I can't find to replace. I'm thinking of taking the outer trim ring off and trying to separate the outer skin from the rotted wood and then laminating it onto new pressure treated ply. Anyone done this before?
Viker-Nokie
Nov 07, 2024Explorer
Hello, I am having a similiar issue with a compartment door having a high moisture level. Same issue here with the decals on the outside. Had 2 doors repaired / resealed by the dealer last year ... Here in Norway the repair cost would start at $450US and up depending on the door size of course.... I've been digging in rabbit holes for someone who has a tube video of this repair but with no luck (Yet)... Curious if you did a repair or a new door? Appreciate and help --- Viker-Nokie 🙂
- way2rollNov 07, 2024Trailblazer
You are responding to a post that's 6 years old and Cam N family hasn't been on here in years. You may have more luck getting responses by posting a new question rather than a response buried in an old thread.
