boogie_4wheel
Aug 25, 2016Explorer
Loose connection on the circuit. The fridge draws power and pulls down the voltage, so the propane side tries to light. Since the fridge is no longer on the 120V power, the voltage on the circuit creeps back up. The fridge sees that AC power is available and tries to switch over, and the cycle continues.
Turn off the 'Auto' on the fridge to force it to gas operation. Shut off the circuit breaker for the outlets with the issue, then check all connection points and prove that they are tight (on the CB, and on the back of the outlets).
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
